Audacity Tracks and Clips
From Audacity Manual
Jump to: navigation, search
  • Ed 29Nov11: given the ongoing talk on "Audio Tracks"... This page only deals with audio tracks its title should reflect that
  • Bill 29Nov11: Yes, this page is about Audio tracks and clips. Perhaps the "Tracks" and "Stereo Tracks" sections should be removed so this page can concentrate on creating and manipulating clips.
    Should "Channels, Tracks and Clips" be on the Audio Tracks page? The information is important, but might clutter up the Audio Tracks page. The definition of a clip is relevant here, but the definition of a channel is more relevant when talking about splitting and joining tracks/channels.
    • Peter 30Nov11:I've been staring at this page and "Audio Tracks" for a while today and I agree with Bill here. I think we can lose the "Tracks" and "Stereo Tracks" sections, probaly replacing them with a link to "Audio Tracks". Also I think that we should try moving the "Channels, Tracks and Clips" section to the Audio Tracks page, I would suggest that we try it as a footnote on that page embedded in a note class div.
    • Peter 2Dec11: Regarding the "Channels, Tracks and Clips" on this page, I'm thinking that "Channel", "Track" and "Clip(s)" may be better as Glossary entries rather than as an introductory section on this page which gets in the way of the "meat" for the reader. We could then put a brief reference and link to the three glossary entries into the intro note.
    • Gale: 03Dec11: The page is about Tracks and Clips, so I think it must define and describe "clips" in more detail than a Glossary should. I do question the validity of the "Channel" bullet. I feel we have not tended to put parts of the Audacity interface in the Glossary, and "channel" (if anything) may be most deserving of a Glossary entry.
    • Bill 03Dec11: Gale, Peter and I have pretty much decided that glossary entries are not appropriate. Unfortunately this discussion is taking place over several pages. That said, please see the talk page for my suggestion for re-working this page.
      For more of this discussion see Audio Tracks.
An Audacity project can contain multiple audio tracks. Each track is normally in one unbroken section, something like a single film clip. However, Audacity can split a track so as to create multiple clips within that track.
Each clip in a track can then be moved around independently, but they all share several properties of the parent track such as its overall volume, panning, sample rate and sample format.
The terms channel, track and clip can be a little confusing, especially because some programs may use them to mean slightly different things. Within Audacity, the meaning is as follows:
  • A channel is for audio input or output. Audacity can record two channels of input (stereo), and more if you have a special sound card or audio device that supports more than two simultaneous channels. Audacity only supports two channels of output, no matter what kind of audio hardware you have.
  • A track is like one instrument in your symphony, or one voice in your podcast. You can add more tracks, and all of them will be mixed together to create your final output, but during editing you can manipulate each track independently. If you have an interview recorded with two microphones, each one can go in a separate track. If you have background music, that could go in a third track. You can move the whole track along the Timeline so that it plays at a different point in time in the mix, but until it is split you cannot move individual parts of it around.
  • A clip inside a track is a separate section of that track which has been split so that it can be manipulated somewhat independently of the other clips in the track. For example, you can split an interview into separate clips for each sentence then move them around individually although they are all from the same track. Or you could move a clip to another track that is panned further right, or split it to a new, empty track. The new track only contains that single clip, so again you can only move that whole track unless you split it into multiple clips.
Splitting a track into clips
When you record some audio or import audio from a file, you get a single track. In many cases, there are natural gaps in the audio - silence between sentences or pauses between phrases in music. Those are good candidates for splitting the track into multiple clips, allowing you to move or otherwise manipulate those clips independently. There are eight ways to create multiple clips in a track.
  • Edit > Split at the cursor or region in an existing track or clip, doing nothing except separating it into multiple clips.
  • Edit > Split Delete at a region in an existing track or clip, removing the selected audio without shifting the following audio.
  • Edit > Split Cut at a region in an existing track or clip, removing the selected audio to the Audacity clipboard without shifting the following audio.
  • Edit > Split New at a region in an existing track or clip, moving the selected audio to the same position in a new track at the bottom of the project.
  • Edit > Detach at Silences at a region in an existing track or clip, creating clips either side of absolute silences.
  • Edit > Paste from the Audacity clipboard into vacant space in an existing track.
  • Generate some audio into vacant space in an existing track.
  • Drag a clip from a different track (or the whole track) into vacant space in an existing track using Time Shift Tool.
As an example, the "before Split " and "after Split" images below show that after selecting Edit > Split, the two boundaries of the gray selection region are overlaid with a solid black split line, marking the boundaries of the three resulting clips.
Gray selection region before Split
Gray selection region after Split showing dark black split lines
Merging or joining clips
Unlike cursor points or selection regions, split lines representing boundaries between clips persist in the waveform of the track until the clips are merged or joined back into one clip.
An adjacent pair of clips may be "merged" into one clip by clicking on the split line to remove it. You can perform a similar "join" action without a mouse by selecting across one or more split lines then using Edit > Join to remove the split lines so as to make one clip.
Time-shifting clips
To move clips around independently, use the Time Shift Tool Time Shift Tool. When you click on a clip and drag it to the left or right, this is called time-shifting because you are changing the time at which that audio will be heard.
Moving a clip after splitting a track into different tracks using Split.
If you click outside a selection area when dragging clips with the Time Shift Tool, the selection area will remain where it was as shown above. Otherwise, the selection area will move with the clip(s).
To move multiple clips at once, select all of the clips you want to move using the Selection ToolSelection Tool, then use the Time Shift Tool to click and drag within the selection area - all selected clips will move together (see before and after figures below).
Creating a selection so you can move multiple clips at once
After moving two clips together
Note that moving clips also makes use of guides, also seen in the chapter on Audacity Selection. When you move a clip, Audacity will snap the left or right boundary of a clip to the nearest edge of a clip in any other track, making it very easy to line up clips during editing.
Time-shifting stereo clips
In most cases time-shifting a clip in a stereo track will work exactly the same way as in a mono track. Most stereo tracks will have continuous audio in both channels and time-shifting a clip will move both channels equally.
Here is an example of a "standard" stereo track.
A standard stereo track with audio in both channels
When you time-shift a clip in this track, both channels move together.
Time-shifting a clip in a standard stereo track
However, there may be times when you will have a stereo track containing separate clips in each channel.
Here we see two mono tracks with multiple clips in each track.
After selecting "Make Stereo Track" from the Track Drop-Down Menu in the upper track, we get this.
stereo track with separate clips in each channel
Here we have positioned the Time Shift pointer over the first clip in the left channel of the stereo track.
ready to time-shift the first clip in the left channel of the stereo track
After dragging with the Time Shift tool, the clip in the left channel has moved independently of the clips in the right channel.
after time-shifting the first clip in the left channel of the stereo track
If you click in the area where the left-channel and right-channel clips overlap, the two clips will move together.
Moving a Clip Between Tracks
The Time Shift Tool can also be used to move a single clip between tracks, but there must be room for the clip between the clips on the second track.
Getting ready to drag a clip from the first track into the second track.
The clip does not fit between the two clips on the second track.
The clip does fit in after the second clip the second track.
Note: If a clip contains a selection area and you click with the Time Shift Tool within the selection area Audacity will not let you drag the clip into another track. To drag a clip containing a selection area into another track, either click in the track with the Selection Tool to remove the selection, or click outside the selection area (but still inside the clip) when dragging.
Personal tools
