Devices Preferences
From Audacity Manual
Interface
- Host: Selects the particular interface with which Audacity communicates with your chosen playback and recording devices. On Windows the choice is between MME (default) or Windows DirectSound and on Linux, between ALSA (default) or OSS. On OS X, Core Audio is used. Generally you will want to use the default. On Windows XP or earlier and a recent computer, DirectSound should produce lower latency.
- Using: Gives the version number and build date of the PortAudio Audio I/O interface library with which Audacity was built.
Playback
- Device: Selects the device used for playback.
Recording
- Device: Selects the device used for recording.
Peter 4Jul11: Commented out the div note as it works fine on our W7 laptop - retained it here as an editornote as I have no idea what Vista behavior is with 1.3.14
On Windows 7 and Vista, each entry for recording device consists of the input type (such as microphone), followed by the name of the audio device the input belongs to. If you have multiple audio devices, the list will be grouped so that inputs of the same type are listed together. Input sources cannot currently be chosen in the Mixer Toolbar Input Selector on Windows 7 and Vista.
- Channels: 1 (Mono), 2 (Stereo) or the number of channels that are provided by the drivers of your sound device. On most inbuilt sound devices, especially on Windows, only mono or stereo will be available. For some devices on Windows, choosing Windows DirectSound in "Host" above may be more likely to reveal options for recording more than two channels. On some devices capable of recording more than two channels, an explicit "multi" device may appear in the "Device" dropdown for recording all the channels simultaneously.
