Edit Chains
From Audacity Manual
Chains may be applied to either the current project, or to a selection of files, using the Apply Chain command.
- Accessed by:
For help with what the Chain effects do and how to set their parameters, see Effect Menu
Chains
Chains contains a list of already defined chains. You can define the name of a new chain and select which chain is active.
- Add: Add a new chain to the list.
- Remove: Remove the selected chain from the list.
- Rename: Rename the selected chain.
Chain
Chain lists the sequence of commands in order of first to last (End) for the chain selected in the "Chains" box to left. Here you can add or remove commands for the selected chain, change the order in which the commands execute in the chain, or edit the parameters for some effects in the chain.
To edit an existing command, double-click it, or use <up> or <down> arrow to select it then press Space. The "Select Command" dialog appears as below, but with the command name and any current parameters displayed and editable (using the "Edit Parameters" button). If you want to replace the current command in its current order in the sequence with another command, double-click the new command (or select it then use Space) then choose "OK".
- Insert: To insert a new command in a Chain, left-click or use <up> or <down> arrow to select an existing command; the new command to be inserted will be placed above this selected command. Then press Insert.
- The "Select Command" dialog appears. Double-click a command from the list to insert it in the "Command" box. Alternatively, use <up> or <down> arrow to select the command, then press Space.
- If the command has editable parameters, the "Edit Parameters" button will be active. Clicking the "Edit Parameters" button will bring up the dialog box for the effect where you can set the parameters as if you were applying the standalone effect.
- Choose "OK" in the effect dialog to accept the parameters you entered, or "Cancel" to revert to the default parameters.
- Choose "OK" in the "Select Command" dialog to add the command to the chain.
- Delete: Delete the currently selected command from the list.
- Move Up: Move the currently selected command up in the list.
- Move Down: Move the currently selected command down in the list.
- Defaults: This button is only active when the "MP3 Conversion" chain is selected in the "Chain" list on the left, and will reset this chain to its default values.
Tips:
- The "Import" command is non-functional at present: To apply a chain to a group of files which are not yet imported, create your chain, choose then choose Apply to Files....
- Parameters for export formats cannot be set in "Edit Chains: To configure export parameters for the chain, click to access the File Export Dialog, click "Options" to set and save the parameters, then cancel the export.
- Each chain is saved as a separate text file with TXT extension in the "Chains" folder in Audacity's folder for application data. This allows you to copy a Chain and send it to another user, or to add another user's Chain to your own list of Chains. An updated Chain will be available next time you open "Edit Chains" in Audacity.
