FAQ:Opening and Saving Files
From Audacity Manual
Jump to: navigation, search
FAQ : Ouvrir et sauvegarder les fichiers Flag of Germany small.png
>  Forward To: FAQ:Editing
<  Back to: FAQ:Playback
|< Index of Frequently Asked Questions
Contents
How do I open an Audacity project (AUP file) in another program?
Audacity project files are saved in a special format that only Audacity can open. To use an Audacity project in another program or burn it to CD, first open the AUP file in Audacity (if you saved it recently it will be in the File > Recent Files menu). Then use the Export commands in the File menu to save the audio in a standard format like WAV or AIFF which may be used by other programs.
To learn more about working with Audacity projects, please see Audacity Projects.
back to top
Why does Audacity create a folder full of .au files when I save a project?
Audacity breaks long tracks into small pieces so it can edit them more efficiently. When you save an AUP project file, Audacity stores all the pieces in a _data folder that has the same name as the AUP file. For example, "song.aup" will open the pieces inside the "song_data" folder.
You should not edit the .au files yourself nor move or rename the _data folder. Open the AUP file and Audacity will load the .au files in the correct sequence automatically.
See also:
back to top
Audacity crashed! Can I recover any unsaved data?
In the event of a crash while Audacity has unsaved data (such as a recording that has not yet been saved as a project, or an existing project with unsaved changes), Audacity will attempt to recover that data on next launch of Audacity. See Recovery for fuller details.
back to top
Can Audacity import or export formats like WMA, AC3 or iTunes files (M4A/MP4)?
Audacity as shipped can import or export the following audio formats:
You can install the optional FFmpeg library to import and export a much larger range of audio formats including AC3, AMR(NB), M4A, MP4 and WMA (on Mac only, Audacity can import unprotected M4A, MP4 and MOV files without FFmpeg). Audio files that are DRM-protected to work only in particular software cannot be imported. FFmpeg will also import audio from most video files or DVDs that are not DRM-protected.
You can export to iTunes by exporting to any location on your computer then add the file to the iTunes library.
See Importing Audio and the File Export Dialog for more help with importing and exporting.
If an audio file you want to import is DRM-protected (for example, an older iTunes M4P file), first burn it to an audio CD in the application that is licensed to play it. Then rip the CD track to WAV or AIFF. You can also record the file as it plays on the computer if your sound device supports this, though this may result in slight loss of quality.
See also:
back to top
Why can’t I play MIDI files?
MIDI files are essentially nothing more than a bare set of instructions describing how to play a series of musical notes. They are thus very different to audio files like WAV which are an actual recording of a piece of music.
For now, Audacity cannot play MIDI files or convert them directly to audio files. You can import MIDI files for visual comparison with audio files, and can perform simple cut-and-paste edits on MIDI files then export as a new MIDI. You can read more about working with MIDI files on this Wiki page.
back to top
How do I import a track from an audio CD?
Audacity cannot import a track directly from an audio CD. You must use a separate program like CDex or iTunes® to extract CD tracks into a format that Audacity can read, like WAV or AIFF.
On Mac OS X computers, CD tracks appear in Finder as AIFF files so can be imported directly into Audacity. For more help on importing audio from CD tracks on both Windows and OS X, see our Wiki help page on How to import CDs.
See also:
back to top
How do I save my recording on an audio CD?
After making a recording or editing a file in Audacity, follow these steps to save your work on an audio CD:
  1. Use the “WAV” or “AIFF” options in the File Export Dialog's "Save as type" dropdown menu to save your Audacity recording in a sound file.
  2. Use any CD-burning software (iTunes® or Nero, for example) to burn this file to a CD. If you burn in a program that is also a media player, like iTunes® or Windows Media Player, you may need to drag the files for burning into a playlist or library. If in doubt, see the program's help files.
To make a disc you can play in normal CD players, make sure to create a “music” or “audio” CD (not a “data” CD). Use CD-R discs, because some players cannot read CD-RW. You can burn only 74 minutes to an audio CD in most cases, but possibly up to 80 minutes depending on the CD-R. This is a limitation of the audio CD format.
Some CD software will burn only 16-bit, 44.1KHz stereo sound files. If your CD recording software won't open your sound file, export the file again after choosing the following settings in Audacity:
  1. At the bottom of the Audacity window, set the Project Rate to 44100 Hz.
  2. If your project does not already contain a stereo track, choose “New Stereo Track” from the Project menu. (This will make Audacity export your recording as a stereo file.)
For helpful tips on CD burning with Windows Media Player or iTunes®, and help on burning longer “data” CDs, see this tutorial in the manual Burning music files to a CD and How to burn CDs on the Audacity Wiki.
See also:
back to top
How can I split a long recording into multiple files or CD tracks?
Follow these steps to create a separate audio file for each song or segment of a long recording. This is particularly useful if you are creating an audio CD, since after burning each file to CD there will be a separate CD track for each song which you can skip to in the CD player.
  1. Click to place the cursor at the start of the first song.
  2. Choose Tracks > Add Label at Selection. If you wish, you can type the name of the song in the label.
  3. Repeat steps 1 and 2 for each song.
  4. When you are finished, choose File > Export Multiple.... When you click the "Export" button, Audacity will save each song as a separate file, using the format and location you choose.
Alternatively, Audacity can attempt to detect the silences between tracks and label them automatically. See the full instructions at Splitting a recording into separate tracks.
See also:
back to top
Why does Audacity warn about the name or nothing happens when I export or save?
If you export an audio file that has a period in the file name (for example, "92.3 FM capture" ), Audacity will warn you, rather than automatically add the appropriate extension for your chosen format. This gives you the flexibility to add a custom extension for a particular file type. For example, to export an AAC file with the .m4b audio book extension, you would add ".m4b" (without quotes) to the end of the file name then answer "Yes" to the warning.
If you need a period in the file name of a standard file type like WAV or MP3, answer "No" to any warning, then add another period followed by the file type at the end of the name. Otherwise, you may not be able to play the file on your computer. For example, to export a file whose full name with extension is "92.3 FM capture.wav", type that name out in full when you export the file:
 92.3 FM capture.wav
and not just "92.3 FM capture".
Gale 07May12: The following could potentially be split into a separate FAQ, but on the whole it's possibly better left as one. The hidden extensions "hint" would have to be in both FAQ's if they were separate.
  • Bill 10May12: This whole "forbidden characters" thing is complex. For example on OS X:
    • Save a project as "Slash/test.aup"
      • The OS saves the file with that name
      • The window title is "Slash:test"
      • In recent files the project name shows as "Slash:test.aup"
      • The file can be successfully opened with File > Open, File > Recent Files, and by double-clicking the AUP file in the Finder
    • Attempt to save a project as "Colon:test"
      • The OS substitutes "-" or ":" in the File Save dialog box, so this can't be done.
    • Attempt to export multiple a label "Track2/1" as aiff
      • Audacity throws the error "Cannot export audio to /path/to/Track2/1.aiff"
    • Attempt to export multiple a label "Track2:1" as aiff
      • The OS substitutes "/" for ":" and the file is successfully saved as "Track2/1.aiff"
When exporting and when saving an Audacity project, Audacity may also warn you (or not respond correctly) if you type a file name that includes characters that are forbidden by the operating system.
Forbidden Characters:
On Windows, all of the following \  /  :  *  ?  "  <  >  |
On Mac OS X, colon only :
On Linux, forward slash only /
Apart from operating system restrictions, Audacity has full support for typable Unicode characters. However, if you want to send your file to someone else or make it available on the internet, only use A to Z characters, numbers and underscores ( _ ) to make sure your file will be compatible.
Windows users: When you check the file you saved or exported in Windows Explorer, you may only be able to see the file name itself (for example, "92.3 FM capture" ) and not the extension following it. This is not an Audacity bug. You will need to set Windows to show extensions for known file types.
back to top
Why does my file import with a hatched pattern then slowly change to a waveform?
See this page: On-Demand Loading.
back to top
I copied the .aup file to another computer or sent it by e-mail to a friend; but now when I open it there's no sound, why?
To use a standard Audacity project on another computer, you have to include the _data folder that has the same name as the project. This makes the size very large. The _data folder has the small .au files that contain the uncompressed audio data.
Also if your project contains imported WAV or AIFF files, you must choose File > Check Dependencies... and if necessary copy in those files to the project before using it on another computer.
See Audacity Projects for more about the structure of Audacity projects and why you would probably need to export an MP3 audio file to make your audio small enough to e-mail.
Alternatively, if you have a broadband internet connection and you package your .aup file and _data folder into a zip file, there are many free file transfer services that allow upload and storage of large files. Try for example minus.com. Audacity also has a feature at File > Save Compressed Copy of Project... to save a much smaller project using OGG files (this will however give you a slightly lossy project).
back to top
Personal tools
