Talk:Audacity Tracks and Clips
From Audacity Manual
Jump to: navigation, search
Ed 2Dec11: Since this page has little to do with tracks and is primarily about clips I think its title is misleading. Maybe Just "Clips" (the Audacity part is also unnecessary).
  • Bill 03Dec11: I agree
  • Peter 3Dec11: I agree too - but note that *many* pages link to this page so care will be needed if we do re-title.
    I like the new proposed content that Bill has put on this page and vote for it to replace the current content..
An Audacity project can contain multiple audio tracks. Each track is normally in one unbroken section, something like a single film clip. However, Audacity can split a track so as to create multiple clips within that track.
Each clip in a track can then be moved around independently, but they all share several properties of the parent track such as its overall volume, panning, sample rate and sample format.
About Clips
A clip inside a track is a separate section of that track which has been split so that it can be manipulated somewhat independently of the other clips in the track. For example, you can split an interview into separate clips for each sentence then move them around individually although they are all on the same track. Or you could move a clip to another track that is panned further right, or split it to a new, empty track. The new track only contains that single clip, so again you can only move that whole track unless you split it into multiple clips.
Splitting a track into clips
When you record some audio or import audio from a file, you get a single track. In many cases, there are natural gaps in the audio - silence between sentences or pauses between phrases in music. Those are good candidates for splitting the track into multiple clips, allowing you to move or otherwise manipulate those clips independently. There are eight ways to create multiple clips in a track:
  • Edit > Split at the cursor or region in an existing track or clip, doing nothing except separating it into multiple clips.
  • Edit > Split Delete at a region in an existing track or clip, removing the selected audio without shifting the following audio
  • Edit > Split Cut at a region in an existing track or clip, removing the selected audio to the Audacity clipboard without shifting the following audio
  • Edit > Split New at a region in an existing track or clip, moving the selected audio to the same position in a new track at the bottom of the project
  • Edit > Detach at Silences at a region in an existing track or clip, creating clips either side of absolute silences
  • Edit > Paste from the Audacity clipboard into vacant space in an existing track
  • Generate some audio into vacant space in an existing track
  • Drag a clip from a different track (or the whole track) into vacant space in an existing track using Time Shift Tool
As an example, the "before Split " and "after Split" images below show that after selecting Edit > Split, the two boundaries of the gray selection region are overlaid with a solid black split line, marking the boundaries of the three resulting clips.
Gray selection region before Split
Gray selection region after Split showing dark black split lines
Merging or joining clips
Unlike cursor points or selection regions, split lines representing boundaries between clips persist in the waveform of the track until the clips are merged or joined back into one clip.
An adjacent pair of clips may be "merged" into one clip by clicking on the split line to remove it. You can perform a similar "join" action without a mouse by selecting across one or more split lines then using Edit > Join to remove the split lines so as to make one clip.
Time-shifting clips
To move clips around independently, use the Time Shift Tool Time Shift Tool. When you click on a clip and drag it to the left or right, this is called time-shifting because you are changing the time at which that audio will be heard.
Moving a clip after splitting a track into different tracks using Split.
If you click outside a selection area when dragging clips with the Time Shift Tool, the selection area will remain where it was as shown above. Otherwise, the selection area will move with the clip(s).
To move multiple clips at once, select all of the clips you want to move using the Selection ToolSelection Tool, then use the Time Shift Tool to click and drag within the selection area - all selected clips will move together (see before and after figures below).
Creating a selection so you can move multiple clips at once
After moving two clips together
Note that moving clips also makes use of guides, also seen in the chapter on Audacity Selection. When you move a clip, Audacity will snap the left or right boundary of a clip to the nearest edge of a clip in any other track, making it very easy to line up clips during editing.
Time-shifting stereo clips
In most cases time-shifting a clip in a stereo track will work exactly the same way as in a mono track. Most stereo tracks will have continuous audio in both channels and time-shifting a clip will move both channels equally.
Here is an example of a "standard" stereo track:
A standard stereo track with audio in both channels
When you time-shift a clip in this track, both channels move together:
Time-shifting a clip in a standard stereo track
However, there may be times when you will have a stereo track containing separate clips in each channel.
Here we see two mono tracks with multiple clips in each track:
After selecting "Make Stereo Track" from the Track Drop-Down Menu in the upper track, we get this:
stereo track with separate clips in each channel
Here we have positioned the Time Shift pointer over the first clip in the left channel of the stereo track:
ready to time-shift the first clip in the left channel of the stereo track
After dragging with the Time Shift tool, the clip in the left channel has moved independently of the clips in the right channel:
after time-shifting the first clip in the left channel of the stereo track
If you click in the area where the left-channel and right-channel clips overlap the two clips will move together.
Moving a Clip Between Tracks
The Time Shift Tool can also be used to move a single clip between tracks, but there must be room for the clip between the clips on the second track.
Ed 2Dec11: in the following table the captions are labels; they are not sentences and should not have terminating periods. They might have colons or (less likely) ellipses and as labels might be in title case.
Getting ready to drag a clip from the first track into the second track.
The clip does not fit between the two clips on the second track.
The clip does fit in after the second clip the second track.
Note: If a clip contains a selection area and you click with the Time Shift Tool within the selection area Audacity will not let you drag the clip into another track. To drag a clip containing a selection area into another track, either click in the track with the Selection Tool to remove the selection, or click outside the selection area (but still inside the clip) when dragging.
Personal tools
