Transcription Toolbar
From Audacity Manual
Jump to: navigation, search
Transcription Toolbar lets you play audio at a slower or faster speed than normal, also affecting pitch. Slower than normal speeds can make it easier to transcribe speech or song lyrics.
Transcription Toolbar showing the special Play-at-Speed button and slider
Transcription Toolbar has its own own Play-at-Speed button which plays audio at the speed set by the Play-at-Speed slider to the right. Playback can be paused and resumed at the adjusted speed. Note that whatever the setting on the slider, using Space or the Play button on the Transport Toolbar to play will only do so at normal speed.
Drag the slider to set a speed from one-hundredth of normal (0.01x) to three times as fast (3.00x), or right-click on the slider then use the keyboard arrow keys to change speed by 0.03x increments. To set a precise playback speed, double-click over the slider (or create a keyboard shortcut for this action), enter the desired speed in the box and click OK.
Gale 05Dec09: Having to click the Play-at-Speed button to change speed was a change made to prevent a freeze on Linux with some buggy versions of PulseAudio. Previously, dragging the slider restarted playback. Please monitor this and change the Manual if the behaviour is changed back.
It isn't currently possible to change speed during playback. To change speed when audio is already playing, change the speed first with the slider, then click the green Play-at-Speed button to play at the new speed. Playback resumes from the original cursor position.
Export... of the audio will be at normal speed whatever the position of the Play-at-Speed slider. To export at an adjusted speed, use Change Tempo... in the Effect Menu to change speed without modifying pitch, or Change Speed... to change speed also affecting pitch.
Personal tools
