Tutorial - Recording audio playing on the computer
From Audacity Manual
Jump to: navigation, search
Peter 2Aug11 wrote initial version of this page.
-Ed 2Aug11 checked/fixed/added links, should all be good now, did a grammar, style & consistency check
Gale 04Aug11: further proofreading and consistency corrections. I removed "Monitoring lets you do this without actually having to record and then delete a test track" in step 3 given we then actually instruct users to make a test recording.
Is the test recording overkill? We already tell them not to exceed -6 dB. Even if we want a section on actually making a test recording, should we have have something on detecting and "fixing" clipping in the actual recording? Remember, it could be an internet radio once-off with no "listen again" option.
  • Peter 4Aug11: Thought long and hard about the Test Recording section today - and on balance I would prefer to leave it in. It is good practice and to be recommended. I screwed up an internet capture today; I turned off Software Playthrough but forgot to change the input device. It all looked ok but I found I had recorded Radio-2 from my FMtuner/Edirol and not the Internet stream (one-off, not repeatable) that was playing on the computer. A test recording would have shown me the error.
  • Gale 06Aug11: I accept the wisdom of ideally making a test recording however this still really doesn't flow all that well for me. It's nice to tell user about monitoring, but what's the point if we say to make a test recording anyway? Really a wasted step except it saves some recording time. Perhaps it may be better to go straight to the test recording step then mention monitoring as a time saver e.g. if you already know you recorded the browser but are now recording from another site.
    Also I still think in the real world people will get clipped streaming recording because they can't get to the web just in time so don't make the tests. We should say something about what you can do to "fix" clipping.
    • Peter 9Oct11: I have added some advice about the use of the Clip Fix effect in the final section on this page.
This tutorial outlines solutions for recording audio playing on the computer, (for example, audio being streamed from an internet web site). How or if you can do this depends on your computer operating system, your sound card and its drivers.
Copyright or web site restrictions may prevent you recording or distributing material. Check first.
Generally, it is better to extract or import audio from CDs, DVDs or existing video or audio files than record them as they play. Recording from an analog sound card is relatively inexact and lossy because the digital source is converted to analog to play it, then back to digital to record it. The resulting quality will depend (amongst other things) on the quality of your sound card's digital to analog and analog to digital converters.
  • To extract audio CD tracks to your computer, see Audio CDs.
  • To import additional types of audio file or extract audio from video files, download and install FFmpeg, then import the file. FFmpeg can also extract audio from the individual VOB files stored on unencrypted DVDs.
-Ed 2Aug11 maybe mention that audio can be ripped from DVDs with details
  • Gale: Probably needs a Wiki page first, in view of the complications. Been on my list for ages.
Step 1: Set up devices to capture computer playback
This is often the hardest part of the overall task, being dependent on your computer operating system and sound card. Many manufacturers are making it increasingly difficult to record streaming audio by deliberately removing or hiding this functionality due to copyright concerns. Sometimes, older sound card drivers can be found on the web site of the sound card or motherboard manufacturer that still allow recording of computer playback.
This section of the tutorial shows how to find a suitable sound card input for recording computer playback, with workarounds if such an input is not available. Click the link to the tutorial for your operating system:
  1. Recording Computer Playback on Windows
  2. Recording Computer Playback on Mac
  3. Recording Computer Playback on Linux
Step 2: Turn Software Playthrough off
Software Playthrough must be turned off when recording computer playback. If playthrough is on, the sound card will try to play what it is recording then re-record it, creating an increasingly loud series of echoes that may damage your equipment.
To turn off Software Playthrough, use the Recording page of Audacity Preferences:
Recording Preferences
You can also choose Transport > Software Playthrough (on/off) to conveniently toggle playthrough off and on as required.
Step 3: Monitor and set initial sound levels
Before recording for real, try to set sound levels by playing similar material from your intended source and monitoring it in Audacity, so that the input level will be neither too soft nor so loud as to risk clipping.
There are two ways to turn monitoring on and off in Meter Toolbar:
  • Left-click in the right-hand recording meter to turn monitoring on. Click again to turn it off.
  • Use the context menu by either left-clicking the downward-pointing arrow beside the microphone symbol or right-clicking over the recording meter. Choose "Start Monitoring" or "Stop Monitoring" as appropriate.
Meter Toolbar drop-down menu showing Monitoring choices (Mac image)
The aim is to adjust levels so that the long red bars in Meter Toolbar don't exceed about -9.0 to –6.0 dB (or 0.5 if the meters are set to linear rather than dB). You can always amplify the recorded signal later if necessary.
Horizontally extended Meter Toolbar showing Current Peak Level of about -9 dB
See Meter Toolbar for a detailed description of what the meter display shows.
Both the output level of the audio you are recording and the level it's being recorded at will determine the achieved input level of the recording. Thus to achieve the correct input level you should use both the input and output level sliders on Mixer Toolbar:
Image of Mixer Toolbar
and probably the volume control on the web site or player software as well. It may be best to check that the Audacity output slider and the web site or player slider are turned up by about the same amount, rather than having one output slider way down and the other way up.
Always keep an eye on the Meter Toolbar recording bars to make sure they don't actually reach the right edge, or the red hold lights to right of the meter will come on, indicating clipping distortion in the recording. Enlarging Meter Toolbar by clicking and dragging the right-hand edge may help with this task. See Undocking and Resizing.
In most cases you can't turn down the output volume (for example, if you want to work) and still record computer playback. If you need to do this, unplug the speakers or on Windows XP or earlier, turn down the "Speaker" slider (not the "Wave" slider") in "Sounds and Audio Devices" in the Windows Control Panel.
Step 4: Make a test recording
Make a test recording to refine levels if necessary.
Start the audio playing on the computer then click the Record button Image of red Record button in Transport Toolbar. Record for long enough to find the loudest likely part, then click the Stop button Image of yellow Stop button.
Have a look at the recorded waveform - there should be no clipping visible. Clipping is bad - this is when the volume of the source sent to Audacity is louder than Audacity can record. The result is that the tops and bottoms of the recorded wave are chopped off ("clipped"). The illustrations below show about 0.004 seconds of a properly recorded waveform then a clipped waveform. You'll need to zoom in to inspect the waveform as closely as this, but extended lengths of clipping will also be visible at lower zoom levels.
A zoomed-in and unclipped waveform
A properly recorded waveform
A zoomed-in waveform showing clipping
A clipped waveform
Gale: Though Show Clipping is convenient, it raises the side issue that it can show clipping when Meter Toolbar doesn't. If this doesn't get remarked on often we could remove the note about that, but I think Show Clipping should be off when making the real recording.
  • Peter 9Oct11:It get's remarked on ofen enough on the forum for me to want to keep the note here. And, personally, I think it is better to leave Show Clipping on all the time, it gets tedious to have to remember to keep turning it on and off all the time. Anyway, if the reader has followed the advice above and limited the maximum recording level to 50% linear or -9dB to -6dB then they shoudn't be getting clipping.
You can also check for clipping by choosing View > Show Clipping from the menu. Audacity will display vertical red lines in the waveform wherever it detects any clipped samples.
Waveform displaying vertical red Show Clipping lines.
  • Show Clipping may detect clipping when Meter Toolbar does not, because Meter Toolbar detects only runs of four or more clipped samples. Any clipping of three samples or less is unlikely to be audible in most recording circumstances, but it's still a good idea to turn the output or input level down if you can.
  • On slower machines it's best to turn Show Clipping off when recording for real.
If clipping occurred, turn the recording or output level down a little and try again.
If no clipping occurred you can now Edit > Undo Record from the menu to remove the test recording(s) then make the real recording.
Step 5: Make the real recording
Click the Record button Image of red Record button in the Transport Toolbar then start the audio playing on the computer. Continue recording for as long as you want, but keep an eye on the "disk space remaining" message (in the Status Bar at bottom left of the Project Window) and on the recording meter (to ensure that you are maintaining a good level without clipping).
When you have finished recording, click the Stop button Image of yellow Stop button.
Step 6: Backup the capture
It is strongly recommended that you Export a safety copy of the raw recording in uncompressed WAV or AIFF format. This is particularly important if the recording is a one-off and cannot be repeated. The backup can always be returned to should you make a mess of your subsequent editing. For extra safety or convenience you could also copy the backup to an external drive or a CD - either a data CD for playing on the computer or an audio or "music" CD for a CD player. Find out more at Audio CDs.
At this stage you will probably want to use File > Save Project before proceeding with any editing. This is useful if you want to come back to editing later on.
Step 7: Editing
For information on editing please refer to this tutorial Recording and Editing
If you have not been able to make a test recording and find that you have some clipping in the real recording then, provided that the clipping is not too severe, you may be able to repair the clipping with Audacity's Effect > Clip Fix .... You should use the Clip Fix effect to repair any clipping immediately after recording and prior to undertaking any further editing.
Personal tools
