Beat Finder
Jump to: navigation, search
Beat Finder attempts to place labels at beats which are much louder than the surrounding audio. It's a fairly rough and ready tool, and will not necessarily work well on a typical modern pop music track with compressed dynamic range.
Tip If you already have a label track and that is included in the selection that you make for the analysis then these labels will be added to your selected label track - possibly causing confusion with your existing labels.
  • Workaround: Ensure you just select audio track(s) and include no label track in the selection for the analysis. Audacity will then create a new label track for the analysis output named "Label Track" - you may wish to rename that so that you remember what the labels in the analysis track refer to.
Accessed by: Analyze > Beat Finder
Threshold Percentage
Sets the beat detection threshold. The default setting is 65%. The setting can be changed by typing directly into the box or by using the slider.
If you do not get enough beats detected, try reducing the "Threshold Percentage" setting.
Links
|< Index of Effects, Generators and Analyzers
|< Analyze Menu
