Ext-Bar Menu
Jump to: navigation, search
The Ext-Bar menu provides access to Toolbar operations that are not available in the default Audacity menus. These will be of most interest to visually-impaired users or those who have difficulty using the mouse.
Shortcuts can be assigned to these commands if required.
This menu can be turned on (or off) at View > Extra Menus (on/off) or the Interface pane of Preferences.
Click, or hover, on any menu item in the image to read about that command.  Skip the image
Help MenuExt-Bar MenuExt-Command MenuMenu BarExtra commands related to play and recordExtra commands to select the tool, eExtra commands related to volumeExtra commands related to editingExtra commands related to play at speedExtra commands related to scrubbingExtra commands related to selecting a deviceExtra commands related to selectingExtBarMenu.png
Transport SubMenu
Extended commands related to play and record. Find out more about the 'Transport' submenu here.
Tools SubMenu
Extended commands to select the tool, for example Time Shift Tool, Envelope Tool or Multi Tool. Find out more about the 'Tools' submenu here.
Edit SubMenu
Extended commands related to editing. Find out more about the 'Edit' submenu here.
Device SubMenu
Extended commands related to selecting a device. Find out more about the 'Device' submenu here.
Mixer SubMenu
Extended commands related to volume. Find out more about the 'Mixer' submenu here.
Transcription SubMenu
Extended commands related to play at speed. Find out more about the 'Transcription' submenu here.
Scrub SubMenu
Extended commands providing menu equivalents for the short and long seek commands which skip the playback cursor backwards (left) or forwards (right) by a short or long period of time.. Find out more about the 'Scrub' submenu here.
Selection SubMenu
Extended commands related to selecting. Find out more about the 'Selection' submenu here.
