Ext-Bar Menu: Transcription
Jump to: navigation, search
The Ext-Bar > Transcription Menu provides commands for manipulating the Transcription Toolbar and for moving between labels.
Click, or hover, on any menu item in the image to read about that command.  Skip the image
Help MenuExt-Bar MenuExt-Command MenuMenu BarExtra commands related to play and recordExtra commands to select the tool, eExtra commands related to volumeExtra commands related to editingExtra commands related to play at speedExtra commands related to scrubbingExtra commands related to selecting a deviceExtra commands related to selectingPlay audio at a faster or slower speedCombines looped play and play at speedCombines cut preview and play at speedDisplays the Playback Speed dialogEach key press will increase the playback speed by 0Each key press will decrease the playback speed by 0Moves selection to the previous labelMoves selection to the next labelExtBar-TranscriptionMenu.png
Play-at-Speed
Loop Play-at-Speed
Play Cut Preview-at-Speed
Adjust playback speed
Displays the Playback Speed dialog. You can type a new value for the playback volume (between 0 and 1), or press Tab, then use the left and right arrow keys to adjust the slider.
Increase playback speed
Each key press will increase the playback speed by 0.1.
Decrease playback speed
Each key press will decrease the playback speed by 0.1.
Move to Previous Label  Alt+Left
Moves selection to the previous label.
Move to Next Label  Alt+Right
Moves selection to the next label.
