Ext-Bar Menu: Transport
Jump to: navigation, search
The Ext-Bar > Transport Menu provides playback commands that are not available in the default Audacity menus.
Click, or hover, on any menu item in the image to read about that command.  Skip the image
Help MenuExt-Bar MenuExt-Command MenuMenu BarExtra commands related to play and recordExtra commands to select the tool, eExtra commands related to volumeExtra commands related to editingExtra commands related to play at speedExtra commands related to scrubbingExtra commands related to selecting a deviceExtra commands related to selectingPlay (or stop) audioStop audioPlays for one second centered on the current <b>mouse pointer</b> position (not from the current cursor position)Plays to or from the current <b>mouse pointer</b> position to or from the start or end of the selection, depending on the pointer positionPlays a short period before the start of the selected audio, the period before shares the setting of the cut previewPlays a short period after the start of the selected audio, the period after shares the setting of the cut previewPlays a short period before the end of the selected audio, the period before shares the setting of the cut previewPlays a short period after the end of the selected audio, the period after shares the setting of the cut previewPlays a short period  before and after the start of the selected audio, the periods before and after share the setting of the cut previewPlays a short period  before and after the end of the selected audio, the periods before and after share the setting of the cut previewPlays audio excluding the selectionExtBar-TransportMenu.png
Play
Stop
Stop audio
Play One Second  1   Extra
Plays 1 second of audio at the current mouse position
Play To Selection  B
Plays from current mouse position to selection
For the following six commands, the amount of audio that is played before, after, or surrounding the selection edge, is set by the Cut Preview setting in Playback Preferences.
Play Before Selection Start  Shift+F5   Extra
Plays a short period before the start of the selected audio.
Play After Selection Start  Shift+F6   Extra
Plays a short period after the end of the selected audio.
Play Before Selection End  Shift+F7   Extra
Plays a short period before the end of the selected audio.
Play After Selection End  Shift+F8   Extra
Play Before and After Selection Start  Ctrl+Shift+F5   Extra
Plays a short period before and after the start of the selected audio.
Play Before and After Selection End  Ctrl+Shift+F7   Extra
Plays a short period before and after the end of the selected audio.
Play Cut Preview  C
Plays audio excluding the selection. The amount of audio that is played before and after the section is set by the Cut Preview setting in Playback Preferences.
