Ext-Command Menu: Focus
Jump to: navigation, search
The Ext-Command > Focus Menu provides provides access to extra commands for track focus that are not available in the default Audacity menus.
Click, or hover, on any menu item in the image to read about that command.  Skip the image
Ext-Bar MenuExt-Command MenuMenu BarExtra commands to set focus, usually focus on one trackExtra commands to move the cursorExtra commands to operate on a track that has focusToggle full screen mode with no title barMove backward through currently focused toolbar in Upper Toolbar dock area, Track View and currently focused toolbar in Lower Toolbar dock areaMove forward through currently focused toolbar in Upper Toolbar dock area, Track View and currently focused toolbar in Lower Toolbar dock areaFocus one track upFocus one track downFocus on first trackFocus on last trackFocus one track up and select itFocus one track down and select itToggle focus on current trackToggle focus on current trackExtCommand-FocusMenu.png
Move backward from toolbars to tracks  Ctrl+Shift+F6
Move backward through currently focused toolbar in Upper Toolbar dock area, Track View and currently focused toolbar in Lower Toolbar dock area. Each use moves the keyboard focus as indicated.
Move forward from toolbars to tracks  Ctrl+F6
Move forward through currently focused toolbar in Upper Toolbar dock area, Track View and currently focused toolbar in Lower Toolbar dock area. Each use moves the keyboard focus as indicated.
Move Focus to Previous Track  Up
Focus one track up
Move Focus to Next Track  Down
Move Focus to First Track  Ctrl+Home   Extra
Move Focus to Last Track  Ctrl+End   Extra
Focus on last track
Move Focus to Previous and Select  Shift+Up
Move Focus to Next and Select  Shift+Down
Toggle Focused Track  Return
Toggle Focused Track  NUMPAD_ENTER
