Extra Menu: Focus
Jump to: navigation, search
The Extra > Focus menu provides provides access to extra commands for track focus that are not available in the default Audacity menus.
The menusHelp menuExtra commands related to play and recordExtra commands to select the toolExtra commands related to volumeExtra commands related to editingExtra commands related to Play-at-SpeedExtra commands related to seekingExtra commands related to selecting a deviceExtra commands related to selectingExtra commands related to Timeline display formattingExtra commands to set focus, usually focus on one trackExtra commands to move the cursorExtra commands to operate on a track that has focusThese commands were originally written for scripting Audacity, for example via a Python script that uses mod-script-pipeLike Scriptables I, but these commands are less commonly used from the menuToggle full screen mode with no title barExtra-FocusMenu.png
Move Backward from Toolbars to Tracks  Ctrl + Shift + F6
Move backward through currently focused toolbar in Upper Toolbar dock area, Track View and currently focused toolbar in Lower Toolbar dock area. Each use moves the keyboard focus as indicated.
Move Forward from Toolbars to Tracks  Ctrl + F6
Move forward through currently focused toolbar in Upper Toolbar dock area, Track View and currently focused toolbar in Lower Toolbar dock area. Each use moves the keyboard focus as indicated.
Move Focus to Previous Track  Up
Focus one track up
Move Focus to Next Track  Down
Focus one track down
Move Focus to First Track  Ctrl + Home   Extra
Focus on first track
Move Focus to Last Track  Ctrl + End   Extra
Focus on last track
Move Focus to Previous and Select  Shift + Up
Advice This command and the next one (Move Focus to Next and Select) are designed to be used to expand or contract focus in a contiguous selection of tracks. If you use them with a non-contiguous selection of tracks you may get unexpected results.
Focus one track up and select it
Move Focus to Next and Select  Shift + Down
Focus one track down and select it
Toggle Focused Track  Return
Toggle selectedness of the track that has focus.
Toggle Focused Track  NUMPAD_ENTER
