Installing and updating Audacity on Linux
Jump to: navigation, search
This page provides instructions for installing and updating Audacity on Linux computer platforms.
  • In addition to basic Audacity you may wish to install the optional LAME MP3 encoding software
  • Also the optional FFmpeg library which allows Audacity to import and export a much larger range of audio formats including M4A (AAC), AC3 and WMA and also to import audio from most video files.
  • Note carefully that simply re-installing Audacity will not clear and reset your Audacity settings for preferences and plugins. For instructions on how to achieve this please see Reset Audacity Settings.
If you are updating from Audacity 2.x or earlier please read Updating from Audacity 2.x to Audacity 3.x as there was a major change to the project file structure when Audacity 3.0.0 was introduced.
Contents
  1. Installation instructions
  2. Check for Updates
  3. Installing LAME
  4. Installing the FFmpeg Import/Export Library
  5. Reset Audacity Settings
The recommended way to install software for most GNU/Linux and Unix-like Desktop distributions, is to install from the official distribution repository using a package manager. Most distributions provide Audacity packages.
Alternatively you can build the latest Audacity tagged release from our source code.
Some old versions of Audacity were incorrectly built. The minimum recommended version of Audacity for Linux is 2.1.2
Note that this Manual only relates to the current release of Audacity.
System Requirements
We recommend using the latest version of GNU/Linux from your distribution that is compatible with your hardware specifications. Audacity will run best with at least 1GB RAM and a 2 GHz processor. Because it was originally written when computers were less powerful, you may be able to run it on much less powerful hardware too. Simple recording is possible on a 700 MHz Raspberry Pi, using a USB Microphone. However, Pi operating systems are not officially supported and Audacity may be less stable on them than on desktop operating systems.
Projects saved by old versions of Audacity
Current Audacity can open project files saved by versions of Audacity 1.2.x and later, including 2.x.x.
These will be converted to the 3.x AUP3 single file format. See Managing Audacity Projects for more details.
Check for Updates
You can check to see if you have the latest version of Audacity by using Help > Check for Updates....
This takes you to the Download page of the Audacity website where you can check what the latest release version of Audacity is.
You can then compare the latest release with the version you have now as shown by using Help > About Audacity....
Installing LAME
Advice When Audacity is installed from the official distribution repository, most distributions also install LAME automatically.
If you have installed Audacity and MP3 export is not available in Audacity, you may download (or compile) then install a compatible version of the LAME MP3 encoder. After installing LAME, it may be necessary to locate it in Libraries Preferences.
Most Linux distributions have some sort of package manager that fetches software packages from the Internet and installs them for you. Open that package manager, search for LAME, and install it if it is not already installed.
Advice If there is not a LAME package for your distribution, go to the LAME Project home page and download the latest source code. Compile it as a shared object. When Audacity prompts you for it, it will be at /usr/local/lib/libmp3lame.so.
This is for advanced users. Inexperienced users are advised to look for a LAME package for their distribution.
Some distributions (for example, current Ubuntu) package Audacity with MP3 encoding and FFmpeg (or Libav) already linked dynamically to the relevant system libraries. In these packaged Audacity builds there is no need to locate LAME or FFmpeg, so Audacity will have no "Libraries" Preferences.
Users compiling Audacity from source code can similarly remove the "Libraries" Preferences by configuring Audacity with --disable-dynamic-loading. Then build Audacity linked to the system LAME (and also to system or locally-compiled FFmpeg or libav if required).
Locating LAME
Advice In most cases, Audacity will locate the LAME library automatically. The instructions below apply only if the LAME option exists in Library Preferences, and you have a compatible version of LAME that is NOT installed in a standard location.
  1. Open Audacity, click Edit > Preferences... then "Libraries" in the list on the left.
  2. In MP3 Export Library, check if a LAME version number displays to right of MP3 Library Version. If so, LAME has already been detected and you should now be able to export MP3 and skip the remainder of these instructions. If the MP3 Library is stated as "not found":
    1. Click the Locate... button to right of MP3 Library
    2. In the "Locate Lame" dialog that appears, click "Browse"
    3. In the "Where is libmp3lame.so.0?" dialog, navigate to the location of the LAME library, select libmp3lame.so.0, click Open, then OK and OK to exit Preferences.
Advice If you are using AppImage to install Audacity 3.0.3, there are currently some issues with loading FFMPEG. Please use the workaround provided here - we hope to fix these issues for the next Audacity release.
The optional FFmpeg library allows Audacity to import and export a much larger range of audio formats including M4A (AAC), AC3 and WMA and also to import audio from most video files.
  • Because of software patents, Audacity cannot include the FFmpeg software or distribute it from its own websites. Instead, use the following instructions to download and install the free and recommended FFmpeg third-party library.
  • Advanced usage: If you already have Audacity-compatible FFmpeg 2.2.x or 2.3.x shared libraries in the system PATH, Audacity will use those as long as you do not install FFmpeg from the links below and as long as you do not specify the FFmpeg you want Audacity to use in Libraries Preferences.
Advice Some distributions (including Ubuntu), include FFmpeg by default when Audacity is installed from the official distribution repository. In this case, no additional installation is required,
Obtaining FFmpeg
You may download (or compile) and install a compatible version of the FFmpeg or libav library for your purposes then locate it in Libraries Preferences.
If you download a pre-built library, this might be either a "shared" or "static" build. A static build consists of a single libavformat library, whereas a shared build has at least three libraries (libavformat, libavcodec and libavutil). It is recommended to use a shared build, but Audacity will also work with a static build.
To build FFmpeg, obtain the source code from the FFmpeg project. To build libav, obtain the source code from the libav project. Configure the build with --enable -shared so that it builds the necessary shared object library (.so) files. If required, you can also configure to enable or disable particular encoding/decoding libraries. When you build Audacity from our source code, it should link to the installed FFmpeg headers.
FFmpeg version support
Advice
  • On GNU/Linux only, Audacity 2.1.3 and later supports FFmpeg/libav up to avformat/avcodec 57.x.x, which is compatible with current FFmpeg 3.x.x/libav 12 releases.
  • Audacity 2.0.6 to 2.1.2 (and 2.1.3 and later on Windows and Mac) support only FFmpeg 1.2 to 2.3.x (libav 0.8 to 10).
  • Compiling Audacity against supported FFmpeg/libav: Dynamic loading (as in default Audacity ./configure) enables Libraries Preferences for manual loading of LAME and FFmpeg/libav but requires building against the FFmpeg project.
  • No-longer-supported FFmpeg/libav: Audacity 2.0.6 and later may still build against unsupported FFmpeg/libav (such as FFmpeg 0.8 which is system-installed on Debian Wheezy), but configuring with --disable-dynamic-loading will usually be necessary. This will cause mono WMA files to export with no audio data.
    See the "Compiling" section in the 2.0.6 or later Release Notes for more guidance.
Removal of Libraries Preferences
Some Linux distributions or versions thereof may package Audacity with MP3 encoding and FFmpeg support already linked dynamically to the relevant system libraries. In these packaged builds there is no need to locate LAME or FFmpeg, so Audacity will have no "Libraries" Preferences.
Users compiling Audacity from source code can similarly remove the "Libraries" Preferences by configuring Audacity with --disable-dynamic-loading. Then build Audacity linked to system LAME and to a system (or locally compiled) version of FFmpeg 1.2 to 3.x.x (libav 0.8 to 12), according to the version of Audacity as described above.
Locating the FFmpeg library manually
Advice Ubuntu / Debian based packages are often built with dynamic loading disabled. When dynamic loading is disabled, LAME and FFmpeg will be loaded automatically if compatible versions are installed and there will not be a "Libraries" page in Preferences.
If you installed FFmpeg while Audacity was running, or if you installed FFmpeg to a non-default location, Audacity will ask you to configure Preferences to locate the FFmpeg library. To do this, click Edit > Preferences... then "Libraries" in the list on the left:
As in the image above, the FFmpeg Library Version will say "not found". To correct this:
  1. Click the Locate... button to right of FFmpeg Library:.
  2. If a "Success" message indicates Audacity has now automatically detected valid FFmpeg libraries and asks if you want to detect them manually, click No, then OK to close Preferences.
  3. If the "Locate FFmpeg" dialog appears, click Browse....
  4. Navigate to the folder that contains FFmpeg and select the file libavformat.so.55 or other appropriate libavformat version.
  5. Click Open then OK and OK again to close Preferences.
FFmpeg Library Version should now show a set of three version numbers for the sub-libraries of FFmpeg ("F" for libavformat version, "C" for libavcodec version and "U" for libavutil version). If you still see "not found", you may have installed the wrong libraries. Click the Download button to obtain the correct library for your operating system. You can also choose Help > Diagnostics > Show Log... to see diagnostic information about FFmpeg detection.
Reset Audacity Settings on Linux
As stated in the introduction on this page, simply re-installing Audacity will not clear and reset your Audacity settings for preferences and plugins.
Tip The easiest way to do this is simply to use Tools > Reset Configuration
The location of Audacity settings
The data for these are stored in a folder called audacity-data:
  1. Open the "home" folder (opens "/home/user-name" in the default file browser)
  2. Use Ctrl + H to show hidden folders (works in most common file browsers, or "View menu > Show hidden files")
  3. There it is: "./audacity-data"
First you will need to quit Audacity.
To completely reset your Audacity settings
Navigate to that audacity-data folder and delete the entire contents. Then restart Audacity.
To reset just your Audacity preferences
Navigate to that audacity-data folder and delete the audacity.cfg file. Then restart Audacity.
To reset just your plugins
Navigate to that audacity-data folder and delete the:
  • pluginregistry.cfg file
  • pluginsettings.cfg file
  • Plug-Ins folder
Links
> Installing plugins on the Audacity Support site.
