Transport Menu: Play
Jump to: navigation, search
These commands control playback in Audacity. You can Start, Stop or Pause playback of the audio in your project.
Click, or hover, on any menu item in the image to read about that command.  Skip the image
View MenuTransport MenuTracks MenuGenerate MenuEffect MenuAnalyze MenuHelp MenuExtra MenuMenu BarThese commands control playback in AudacityThese commands control recording in AudacityScrubbing is the action of moving the mouse pointer right or left so as to adjust the position, speed or direction of playback, listening to the audio at the same time - a convenient way to quickly navigate the waveform to find a particular event of interestThese commands let you move the cursor to the start or end of the selection, track or any adjacent Clip that you may haveThese commands enable you to lock a play region and unlock itRescan for audio devices connected to your computer, and update the playback and recording dropdown menus in Device ToolbarThis submenu lets you manage and set various options for transport (playing and recording) in AudacityStarts and stops playback or stops a recording (stopping does not change the restart position)Starts playback like "Play/Stop", but stopping playback sets the restart position to the stop pointPlays the selection over and over againTemporarily pauses playing or recording without losing your placeTransport-PlayMenu.png
Click for details
Click on the image to learn more
Play/Stop  Space
Starts and stops playback. If a region of a track is selected, this command will play only that selection then playback will stop. Otherwise, playback begins wherever the editing cursor is and continues until the end of the project is reached. Starting playback with this command is the same as clicking the Play button Play button in Transport Toolbar.
When there is already playback or recording (or playback or recording is paused), this command stops playback or recording immediately without changing the selection region or the position of the editing cursor. Therefore using any play or record command after stopping with "Play/Stop" will start playback or recording from the same Timeline position it last started from. Stopping playback with this command is the same as clicking the Stop button Stop button in Transport Toolbar.
If you want to set separate keyboard shortcuts for Play and Stop you can do this in Keyboard Preferences.
Play/Stop and Set Cursor  X
Starts playback exactly like "Play/Stop", but stopping playback (or recording) sets the editing cursor, or the left edge of the selection region, to the stop point so that playback can be resumed from there.
Loop Play  Shift + Space
Plays the selection over and over again. Same as holding the Shift key while clicking the Play button Play button in Transport Toolbar.
Pause  P
Temporarily pauses playing or recording without losing your place. Same as clicking the Pause button Pause button in Transport Toolbar.
<  Back to: Transport Menu
