Transport Menu: Record
Jump to: navigation, search
These commands control recording in Audacity. You can Start, Stop or Pause recording in your project.
You can either start a recording on your existing track or an a new track.
There is also a Timer Record function to enable you to make unattended timed recordings.
Click, or hover, on any menu item in the image to read about that command.  Skip the image
View MenuTransport MenuTracks MenuGenerate MenuEffect MenuAnalyze MenuHelp MenuExtra MenuMenu BarThese commands control playback in AudacityThese commands control recording in AudacityScrubbing is the action of moving the mouse pointer right or left so as to adjust the position, speed or direction of playback, listening to the audio at the same time - a convenient way to quickly navigate the waveform to find a particular event of interestThese commands let you move the cursor to the start or end of the selection, track or any adjacent Clip that you may haveThese commands enable you to lock a play region and unlock itRescan for audio devices connected to your computer, and update the playback and recording dropdown menus in Device ToolbarThis submenu lets you manage and set various options for transport (playing and recording) in AudacityStarts recording at the end of the currently selected track(s)Recording begins on a new track at either the current cursor location or at the beginning of the current selectionBrings up the Timer Record dialogTemporarily pauses playing or recording without losing your placeTransport-RecordMenu.png
Click for details
Click on the image to learn more
Record  R
Clicking Record or using the R shortcut always begins recording at the end of the currently selected track(s).
Record New Track  Shift + R
This will cause Audacity to create a new track and begin recording on that track from the current cursor position (or from the left edge of a region on the Timeline). Starts recording at the end of the currently selected track(s). Append Record can also be started by holding Shift while clicking the Record button in Transport Toolbar. When you hold down the Shift key the Record button will change to the Record New Track The Record New Track button button.
Timer Record...  Shift + T
The Timer Record dialog, click for details of usage.
Brings up the Timer Record setup dialog for scheduling when a recording ends and optionally, when it begins. Pressing "OK" starts the process of recording, or waiting for the recording to start.
For full details of the timer recording function please see the Timer Record page.
Pause  P
Temporarily pauses playing or recording without losing your place. Same as clicking the Pause button Pause button in Transport Toolbar.
<  Back to: Transport Menu
