Import / Export Preferences
Jump to: navigation, search
Accessed by: Edit > Preferences > Import / Export    (on a Mac Audacity > Preferences > Import / Export )
Audio Settings PreferencesPlayback PreferencesRecording PreferencesMIDI Devices PreferencesQuality PreferencesInterface PreferencesTracks PreferencesTracks Behaviors PreferencesSpectrograms PreferencesImport/Export PreferencesExtended Import PreferencesLibraries PreferencesDirectories PreferencesWarnings PreferencesEffects PreferencesShortcuts PreferencesMouse PreferencesModules PreferencesApplication PreferencesClick on this in Audacity to get helpPreferences Import Export.png
Exported Label style
  • Standard: exports the start and end times of the label followed by the label name (this is the default setting).
  • Extended (with frequency ranges): exports as above, adding any frequency selection that exists for the label.
Exported Allegro (.gro) file saves time as
When using File > Export Other > Export MIDI you can export to .mid or .gro extension. The .gro extension signifies the Allegro file format which exports the Audacity Note Track as human-readable plain text. This preference controls whether the .gro file represents time and duration in seconds (default) or beats.
  • Seconds: An example line in the .gro file would look like:
       T1.3330 V0 K66 P66 U0.6660 L127
    This instruction means "play key number 66 at time (T) 1.333 seconds for duration (U) 0.666 seconds."
  • Beats: An example line in the .gro file would look like:
       TW0.5000 V0 K66 P66 Q1.0000 L127
    This instruction means "play key number 66 at time (T) 0.5 whole notes (W) for duration (Q) 1 quarter notes."
Tip Audacity can import both .mid and .gro files for display, editing and playback. The .gro files will be imported correctly whether they contain data in seconds or beats.
However many general purpose MIDI applications will not play .gro files.
