Select Menu: Audio Clips
Jump to: navigation, search
A set of commands to enable you to make selections based on any Clips that you may have in the project.
Tip Clips and what you can do with them are explained on page Audacity Tracks and Clips.
Previous Clip Boundary to Cursor
Previous Clip Boundary to Cursor and the three related commands below Cursor to Next Clip Boundary, Previous Clip and Next Clip use the clips in the selected track or tracks. If no tracks are selected, the clips in all tracks are used.
Selects from the current position of the editing cursor or selection backwards to the previous clip boundary, so extending the selection with each use to include further clips (or blank space) until the start of the track is reached.
Example:
Starting with this selection ...
after the first command the selection is extended from the editing cursor position to the start of the clip:
after the second command the selection is extended to the end of the previous clip:
and after the third command the selection is extended to the start of the previous clip:
Selects from the current position of the editing cursor or selection forwards to the next next clip boundary, so extending the selection with each use to include further clips (or blank space) until the final clip is reached.
Example:
after the first command the selection is extended from the editing cursor position to the end of the clip:
after the second command the selection is extended to the start of the next clip:
and after the third command the selection is extended to the end of the next clip:
Previous Clip  Alt + ,
Moves or creates a selection so as to fully select in the current clip where the editing cursor or selection is. However if that cursor is already exactly at the start of the current clip or if the current clip is already fully selected, this command will fully select in the previous clip. Further use of Previous Clip then fully selects in the previous clip until the first clip is reached.
Example:
after the first command the clip containing the cursor is selected:
after the second command the previous clip is selected:
Subsequent commands will do nothing since the first clip in the track is selected.
Next Clip  Alt + .
Moves or creates a selection so as to fully select in the next clip. If the editing cursor is exactly at the start of a clip, this command selects all of that current clip.
Example:
after the first command the next clip is selected:
after the second command the next clip is selected:
Subsequent commands will do nothing since the last clip in the track is selected.
Tip To move the editing cursor to the start of the next or previous clip without selecting its audio, see the Transport > Cursor to commands for Previous Clip Boundary and Next Clip Boundary.
<  Back to: Select Menu
