Analyze Menu
Jump to: navigation, search
The Analyze Menu contains tools for finding out about the characteristics of your audio, or labeling key features. Plugins that accept audio input but produce no audio output will be placed in the Analyze menu, with the analysis results being provided by labels (or in some optional LADSPA plugins by an "Effect Output" section in the plugin itself).
Tip For analyzers that you use often you can use Keyboard Preferences to set up keyboard shortcuts for those Generators. You can also set up a custom shortcut for Repeat Last Analyzer.
  • Many of the analysis tools shipped in Audacity are Nyquist plugins which can be edited in any text editor. You can download additional Nyquist analysis plugins. The built-in analyzers are LADSPA effects. Some additional LADSPA analysis plugins for Linux can be downloaded from http://www.ladspa.org/.
  • The description page for each shipped analysis effect (accessed by the links below) shows an image of the interface and its default settings.
Audacity's Analysis Tools
Plugin Manager
Selecting this option from the Analyze Menu (or the Effect Menu or Generate Menu) takes you to a dialog which enables you to load and unload Analyzers (and Effects and Generators) from Audacity. This enables you to customize your Analyze Menu making it shorter or longer as required. For details see Plugin Manager.
Additional plugins can also be loaded into Audacity. For details see Installing plugins on the Audacity Support site for plugin installation details for all three platforms.
See also this list of available Nyquistplugins on the Audacity Support site, that you can easily download and add to Audacity.
Backing up or transferring settings
To see how to backup your settings, last used and any user presets you have saved using the Manage button in each analyzer's dialog, see this page.
Built-in LADSPA analysis tools
Contrast  Ctrl + Shift + T   Extra
Analyzes a selected, single non-stereo audio track to determine the average rms difference in volume (contrast) between foreground (the speech) and background (music, audience noise or similar). The purpose is to determine if the speech will be intelligible to the hard of hearing.
Plot Spectrum
Takes the selected audio (which is a set of sound pressure values at points in time) and converts it to a graph of frequencies (the horizontal scale in Hz) against amplitudes (the vertical scale in dB).
Find Clipping
Displays runs of clipped samples in a Label Track, as a screen-reader accessible alternative to View > Show Clipping in Waveform. A run must include at least one clipped sample, but may include unclipped samples too.
Nyquist Plugin analysis tools shipped with Audacity
Beat Finder
Attempts to place labels at beats which are much louder than the surrounding audio. It's a fairly rough and ready tool, and will not necessarily work well on a typical modern pop music track with compressed dynamic range.
Measure RMS
A simple analyzer to measure the RMS (Root Mean Square) levels in a track.
Measure RMS is not enabled by default. To enable it, use Analyze > Plugin Manager   to open the Plugin Manager dialog. There you will find the file listed as "rms", but it will enable as Measure RMS.
Label Sounds
Label Sounds is a tool which can useful to label the different songs or sections (or silences) in a long recording.
There are options to add point labels before or after each detected sound, region labels around each sound, or region labels between each sound (effectively labeling the silences).
Tip The Label Sounds tool is very useful to label the different songs or sections in a long recording, such as the tracks from an LP or cassette.
Vamp Analysis Plugins
You can also add some additional analysis tools in the Vamp plugin format for viewing and analysing the descriptive contents of music audio files. Typical things that a Vamp plugin might calculate include the locations of moments such as note onset times and power or fundamental frequency data. Plugins that produce graphs or other visuals will not work in Audacity, only plugins that are suitable for writing to labels.
To add a new Vamp analysis tool, add the plugin's DLL, DYLIB or SO file (and any supplied category (CAT) or RDF (TTL or N3) files) to one of the paths listed in the green box below.
To run a Vamp plugin, select the audio and run the plugin from the menu. An annotated label track appears showing the result.
Advice Currently Audacity cannot load Vamp plugins from the Audacity "Plug-Ins" folder.
Vamp plugins are loaded from the following standard directories each time you launch Audacity:
  • On all platforms: any directories listed in the VAMP_PATH environment variable
  • additionally on Windows:
    • C:\Program Files\Vamp Plugins.
  • additionally on macOS
    • ~/Library/Audio/Plug-Ins/Vamp (user plugins)
    • /Library/Audio/Plug-Ins/Vamp (system-wide plugins)
Tip On Mac the folders that you need may be "hidden". To access them in Finder use  Go > Go To Folder > ~/Library ...    or   Go > Go To Folder > /Library ...
The Go is in the menu bar at the top of the desktop when Finder is active.
  • additionally on Linux/Unix:
    • $HOME/vamp
    • $HOME/.vamp
    • /usr/local/lib/vamp (user plugins)
    • /usr/lib/vamp (system-wide plugins).
