Directories Preferences
Jump to: navigation, search
Accessed by: Edit > Preferences > Directories    (on a Mac Audacity > Preferences > Directories)
Devices PreferencesPlayback PreferencesRecording PreferencesQuality PreferencesInterface PreferencesTracks PreferencesSpectrograms PreferencesImport/Export PreferencesExtended Import PreferencesProjects PreferencesLibraries PreferencesWarnings PreferencesEffects PreferencesKeyboard PreferencesMouse PreferencesModules PreferencesDirectories Preferences dialog
Directories Preferences dialog showing the default temporary session data location on Windows Vista and later
Click on any of the other Preferences sections in the above image to go directly to that Preferences page.
Temporary files directory
  • Location: Sets the location of Audacity's temporary directory for session data. This is used whenever there is audio data that has never been saved as an Audacity project.
    To change the location of the temporary directory, press Choose..., select the directory you require and click OK. Audacity will then create a session workfile sub-directory in the directory you selected. Alternatively type the path required for the temporary directory into "Location" and Audacity will use that exact path, creating the new directory if needed.
    Exit and restart Audacity for changes to the temporary directory to take effect.
    Make sure the temporary directory is located on a fast (local) disk drive with plenty of free space. Avoid using network drives as these may be too slow for reliable recording. A RAM drive will always be quicker than a hard or solid state drive for recording and editing, but unless the RAM contents are saved to a physical drive the data will be lost when the computer powers down.
Default location of Temporary Folder:
  • Windows Vista or later: C:\Users\<your username>\AppData\Local\Audacity\SessionData
  • Windows XP: C:\Documents and Settings\<your username>\Local Settings\Application Data\Audacity\SessionData
  • macOS/Mac OS X: /Users/<your username>/Library/Application Support/SessionData
  • GNU/Linux: /var/tmp/audacity-<your username>
Warning icon If your drive does not have sufficient space, you can reduce the space taken by temporary data by going to the Quality tab of Preferences and reducing the default sample format and sample rate. Reducing the sample rate will noticeably reduce higher frequencies, so is only recommended for speech data.
Views
Donate securely by PayPal, using your credit card or PayPal account!
Useful External Links
