Cassette deck de-magnetization
De-magnetizers are sometimes used in an attempt to improve cassette playback quality, but their value is open to debate.
Contents
Cassettes
De-magnetizers are sometimes used on cassette decks, but they are rarely needed, and usually don't produce enough field strength to de-magnetize.
Head magnetization used to occur sometimes on early decks using DC erase, for 2 reasons.
- The tape magnetized by DC erase had a very slight tendency to magnetize the record/play head(s) over time.
- The metal the heads were made from was relatively easy to magnetize.
DC erase has not been used on anything but cost-cutting decks in decades. However permanent magnet erase is found on some modern low cost decks, and does effectively the same thing as DC erase.
Tape head technology has come a fair way, and modern head materials are not as vulnerable to magnetization as was once the case. This also means they aren't as susceptible to de-magnetization, and a de-magnetizer is not normally capable of either magnetizing or de-magnetizing a cassette deck head.
De-magnetizers
If you really do need to de-magnetize a tape head, a hand-held tool does not normally produce enough field strength to do so.
Studios use much larger higher power de-magnetizers to produce enough field to erase tapes. These items weigh several kilos and may consume 500w or so. De-magnetizing a tape head requires greater flux density than for erasing tapes.
Magnetizing a head takes more flux density than recording a tape. This has to be the case for all tape heads, otherwise they'd magnetize themselves in normal use. So if your de-magnetizer can't erase a tape completely, you can be sure it won't de-magnetize any tape heads.
Reel-to-Reel
The situation is different with open reel decks, because many of these date back to the 1950s and 60s, and use more easily magnetized head materials.
Connecting a multimeter to the erase head can tell you whether it uses AC or DC erase. The better AC erase decks should not suffer any tendency to magnetization.
If you have a DC erasing deck, the deck will normally have more quality problems than simply the DC erase itself. It is possible to convert these decks to AC erase if really desired, but almost no-one would want to use a sub-optimal open reel deck for regular recording today.
8-Track
Most 8-track decks don't record, so have no erase system, and thus nothing to magnetize the head. Magnetization is unlikely in these decks.
For magnetization to occur would require:
- A susceptible head
- Use of DC erase
- A lot of recording use
Magnetization is also unlikely in recording decks where the record function is not used a lot.
8-track de-magnetization cartridges
The de-magnetization cartridges sold in the 1970s are ineffective. They used small permanent magnets and lack the necessary field strength.
