Other plugins and tools for fades
Jump to: navigation, search
This page lists some downloadable or more advanced tools for making fades.
Contents
  1. Fade In and Out
  2. Text Envelope
  3. Creating Fades from the Nyquist Prompt
Fade In and Out
This is a Nyquist plugin that can apply a linear fade in and fade out to the selected audio.
Nyquist plugins extend the capabilities of Audacity and are supported on Windows, Mac and GNU/Linux. Instructions for installing Nyquist plugins can be found on thi page Nyquist Plug-in Installer
This tool was written by David R Sky to provide a simple, accessible way for visually impaired and other non-mouse users to apply fade in and out effects. The current Audacity 2.x has a Selection Toolbar providing a screen-reader friendly display of selection start time and duration (* except on Linux) which can be used for similar purpose, but this effect may be found to be quicker and easier to use.
Text Envelope
This is a Nyquist plugin that can apply multiple changes to the amplitude of the selected audio, fading from one level to another as required.
This tool was written by Steve Daulton to provide an accessible alternative to the "Envelope Tool" for visually impaired and other users that do not use pointing devices.
Nyquist is a programming language that is included in Audacity. It can be used to write plugins for Audacity that may provide new effects, generators and analysis plugins. Nyquist commands may also be run directly in Audacity by entering code into the Nyquist Prompt. Below are a few short code samples that may be run in the Nyquist Prompt to produce fades to selected audio. More information about Nyquist programming may be found on the Nyquist page.
The code examples below require that the "Legacy (version 3) syntax" option is NOT selected
; Linear Fade Out:
(mult *track* (pwlv 1 1 0))
; Linear Fade In.
; To avoid a click at the end, the pwlv envelope
; extends beyond the end of the selection.
(mult *track* (pwlv 0 1 1 1.1 1))
; Multi-step fade out.
(mult *track* (pwlv 1 0.4 0.775 0.8 0.447 0.9 0.316 0.95 0.224 1.0 0.0))
; sine curve fade in:
(mult *track* 0.5
  (sum 1
    (osc (hz-to-step (/ (get-duration 2)))
      1 *table* -90)))
; wiggly fade:
(setf wiggle (mult 0.2 (hzosc (/ 6.0 (get-duration 1)))))
(mult *track* (sum 1.0 wiggle))
; wiggly fade out:
(mult *track* (pwlv 1 1 0) (sum 1.0 wiggle))
