Warnings Preferences
Jump to: navigation, search
Warnings preferences let you disable or re-enable various advisory prompts or warnings.
Advice You cannot turn off the warning to Save your project when exiting Audacity if you have made changes since you last save the project.
Accessed by: Edit > Preferences > Warnings    (on a Mac Audacity > Preferences > Warnings )
Audio Settings PreferencesPlayback PreferencesRecording PreferencesMIDI Devices PreferencesQuality PreferencesInterface PreferencesTracks PreferencesTracks Behaviors PreferencesSpectrograms PreferencesImport/Export PreferencesExtended Import PreferencesLibraries PreferencesDirectories PreferencesWarnings PreferencesEffects PreferencesShortcuts PreferencesModules PreferencesApplication PreferencesCloud PreferencesPreferences Warnings.png
Show Warnings/Prompts for
Saving projects versus exporting audio
Every time you save a standard Audacity project Audacity will warn that this command is only for an Audacity project and that you must use the export audio command to produce an audio file that you can open in other applications. Once you understand this, you can turn off this warning from within the warning dialog.
Advice Note carefully that this preference does not enable you to turn off the warning message that you get when closing Audacity without saving your project, that warning cannot be turned off.
Saving empty project
Audacity will warn when you try to save (left-hand image) or close (right-hand image) a project that previously contained tracks but is now empty. This warning can only be turned off in Preferences (not by a checkbox in the warning) because of the risk of accidental data loss if the warning is disabled.
Low disk space at application start up
This warning message can no longer be turned off in Warnings preferences or in the warning dialog itself as it is deemed a critical warning.
Audacity will warn on start up or when using File > New to create a new project if you have 100 MB or less space in the temporary folder for recording or editing.
100MB is approximately 5 minutes of stereo audio or 10 minutes of mono audio at default settings.
