Draw Tool
- The draw tool can be used for freehand repair or for smoothing.
- Draw tool is unavailable while paused.
The image above shows the Tools Toolbar with the Draw Tool selected.
- Click on this link to learn more about the Tools Toolbar.
- Click on other tools in the image to learn more about those tools.
Selection Tool will always be selected upon reopening Audacity, irrespective of which of the separate tools was selected when you quit. |
When zoomed in close to maximum level, the Draw Tool enables you to adjust the volume level of individual audio samples. The closer the sample is to the horizontal line through the center of the track, the quieter the sample will be.
Draw Tool can be used to eliminate narrow clicks and pops in audio by smoothing out the contour of the samples, so that one sample is not at a very different vertical position to its neighbors.
How to use the Draw Tool
Freehand repair
Click above or below a sample to move it to that vertical position. You can keep holding the mouse and drag up or down to move the sample to the exact position required. Dragging left or right moves adjacent samples to the current vertical position of the mouse pointer.
If you only want to move one sample, hold down Ctrl before clicking. This ensures that no other samples are affected, even if you drag slightly left or right by accident.
Smoothing
Smooth the vertical disparity in a group of samples by holding down Alt (or Ctrl + Alt on Linux). This changes the mouse pointer to a brush (or spray can on Linux). Position the pointer halfway along the group of samples then click repeatedly to progressively smooth the group.
For very short lengths of audio up to 128 samples long, you can smooth out audio automatically with Repair tool under the Effect Menu |
